Home > Technical (L322) > More electrical gremlins :( Steering lock not working - help
T24RES
Banging Head Censored Thud
Today's special problems:
1. Tyre pressure system fault.
2. Put key in ignition, turn key and no ignition lights. Ignition lights come on after many repeat actions.
3. Followed by transmission reduced gears etc,
4. When removing the key, steering lock doesn't engage.
Is this all connected to my Censored luck electrical problems?
IID tool is on its way and if only it would stop raining i could check for parasitic battery drain with the meter. Ian
Post #241544 9th Feb 2014 10:40pm
T24RES
Ok 1-3 have disappeared for the moment. Anyone have any ideas about the steering lock not engaging. The only post I found was from RRUK, but I guess he sold his TDV8 which solved it Sad Ian
Post #241782 10th Feb 2014 10:10pm
crikey , its all happening for you Ian.. Shocked
first thing i would do is to double make sure the battery is ok and the alternator is pushing out 14.5 volts on idle.....
after that, ?
Post #241808 10th Feb 2014 11:07pm
T24RES
All working now. Ian
Post #241984 11th Feb 2014 5:36pm
Welshdragon
What was the out come Ian ? Battery issue? If it dont work.......burn it!
Post #241988 11th Feb 2014 5:43pm
Ian pulled and refitted a fuse on the tow electrics..
Post #241990 11th Feb 2014 5:45pm
