Home > For Sale & Wanted > [Wanted] Warn 9.5 Ti winch
verydisco
Hi gang
following this thread (http://www.fullfatrr.com/forum/topic20566....arn+9+5+ti), i am looking for a Warn 9.5 Ti winch, ideally in mint condition or to be refurbished, before I get a 9.5 STi from Warn.
Cheerio
 l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #242186 12th Feb 2014 2:00pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
we have one on the shelf at work, needs a new motor if i remember correctly. i can check on it after half term.
Post #242577 13th Feb 2014 11:22pm
verydisco
please do
tx Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #242581 13th Feb 2014 11:29pm
JST
i have asked them to send some pics across, will post up when they arrive.
Post #242662 14th Feb 2014 3:25pm
verydisco
Current
Previous:
Post #242665 14th Feb 2014 3:48pm
JST
Post #242725 14th Feb 2014 9:08pm
JST
As promised.
it needs a clean, all rotates as it should, no tight spots. is off an ex demo vehicle.
i believe the motor may be coming off - would need to confirm if you are interested.
cables have been cut as you can see from pics.
i cant vouch for the solenoids. if required i can invest some time on it and clean it up, check it works and fit new motor/solenoids/cables as required?
or make an offer as it stands with and without the motor.
Please note i am away now for a while - back end of next week.
Post #242728 14th Feb 2014 9:11pm
verydisco
Hi
I would appreciate if you could find out what needs to be done to it or how much they'd vant for it as is and I will get it refurbished altogether.
thank you in advance. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #242756 14th Feb 2014 11:06pm
JST
i can get a price for it as is, no problem.
If you want a list of what needs doing then someone will need to look at it which means the price will go up as it will incur a cost to get someone to look at it, if they are going to look at it they may as well fix it?
Post #242861 15th Feb 2014 6:58pm
verydisco
Hi , would you mind asking the price for the winch as is and the one refurbished altogether ?
thanks again Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #242905 15th Feb 2014 10:49pm
JST
am now back, will sort this next week with them on both accounts.
Post #243688 19th Feb 2014 10:17pm
verydisco
Current
Previous:
Post #243691 19th Feb 2014 10:21pm
JST
sorry for the delay, i should know conditon and prices by end of next Tue so will update post then
Post #245267 27th Feb 2014 2:37pm
verydisco
Great, thanks l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #245274 27th Feb 2014 2:45pm
JST
have finally had some time to look over the winch.
previous use is unknown so i have no idea of how hard it has worked in the past. Brush pack would indicate not a great deal has been done with it, solenoids and motor work as to be expected. Freespool and gear engagement all working. i have bench run it but not tested it under load. Everything works as it should.
It needs a remote, std Warn 6 pin, plus the battery supply cables, both earth and the positive to go from the unit back to the battery. std 35mm2 cabling would work.
I dont know the wire cables history, if it were me looking to buy i would replace the cable as a matter of course.
Would be sold as seen.
Owner is looking for £650 as is.
if you wanted wire cabling and the electrical cabling this could be sourced too.
Post #247756 12th Mar 2014 1:56pm
