![]() | Home > Technical (L322) > Supercharged Coolant pump |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Dave, fill in your car profile pal or you will be asked constant questions about age and model etc etc when posting questions on here... |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 ![]() ![]() ![]() |
Good point it does make life easier I suppose. Just filled it in. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1400 ![]() ![]() |
http://www.fullfatrr.com/forum/topic22717.html
That's great thanks I will check my vin this morning.
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
But how would you know if all the issues "have" been dealt with ?. |
Yep as suspected my vin falls within the affected models. Will get a new pump ordered and the pins swapped to be on safe side.
in most cases just repinning the connector to the correct orientation will sort out the issue
Thanks for that will report back as soon as it's done. The difference between theory and reality is that in theory it will work. |
Just an update. I've replaced my aux coolant for a genuine Bosch one. The wiring was also the wrong way round on mine as per technical bulletin. It was a pretty straight forward job and only took around an hour.
