Home > Maintenance & Mods (L322) > woe is me - coolant leak |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
Hi All,
18th Feb 2014 9:29am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Heres a start but it will likely be something unrelated to the issue I had:
18th Feb 2014 10:29am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
if your coolant level was ok before then you've dislodged a pipe whilst doing the oil change.. |
18th Feb 2014 10:37am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
My leak was this after a rad change.. water pump bolt and O ring .
18th Feb 2014 11:11am |
Sorry replied to whelshdragons orignal post
18th Feb 2014 11:50am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
The altenators do like to spring leaks on earlt 4.4's too |
18th Feb 2014 12:12pm |
spent the last hour looking but no sign of any leaks |
18th Feb 2014 12:46pm |
with the engine running? |
18th Feb 2014 1:00pm |
yep and after switched off for a while also. |
18th Feb 2014 1:27pm |
strange that you have to add so much coolant after a relatively short drive..sometimes using kitchen towel tissue can find minute sprays.. |
18th Feb 2014 1:30pm |
I think this is a hangover from my oil change. Left of image is front of car looking from under near side wheel arch. It appears to be loosing about 1ltr every 20 miles.
18th Feb 2014 5:39pm |
Found it - back of the engine above the bell housing. Looks like the engine to changover valve hose/coupling.
18th Feb 2014 6:21pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Part number JHC000081.
18th Feb 2014 7:42pm |
Thanks Steptoe, Looks like the right part. |
18th Feb 2014 8:35pm |
