Home > Maintenance & Mods (L322) > HDC & Handbrake
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
HDC & Handbrake
I fitted a replacement gear lever surround yesterday using the switches from my old tatty one and at the same time installed my PURE DAB radio with the control boxed under the cup holder.
I connected all the connectors correctly to the panel and it was working in an early test (before PURE fitted). Today the HDC doesn't work and I have had a couple of errors come up to say its inactive. Also I don't get a warning light if I use the hand brake and the TV only works like if I am driving (even with handbrake fully on) I am guessing that I have knocked off a sensor or disconnected a wire when putting back together. I will have a look around tomorrow or over the weekend but any ideas on where the handbrake sensor is, what it looks like or other ideas appreciated. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #243835 20th Feb 2014 3:41pm
rej
Any ideas where I should be looking to see if I have dislodged / disconnected the handbrake sensor or whatever picks up the signal that the handbrake is applied. There is a difference between knowing your sh!t and knowing you're sh!t
Post #244025 21st Feb 2014 2:20pm
rej
Update
Handbrake light sorted. A cable from the DAB control to the iPod was stopping the sensor from releasing.
No HDC or Low Range still do I think that the switch pack must be knackered where I transferred if from the old to new trim. Any idea where I can get a working switch pack, PowerfulUk have one for a couple off hundred although I only want the underside so a working tatty example would be fine. There is a difference between knowing your sh!t and knowing you're sh!t
Post #244122 21st Feb 2014 8:14pm
rej
New central panel sorted the problem. There is a difference between knowing your sh!t and knowing you're sh!t
Post #244963 26th Feb 2014 10:56am
