Home > Technical (L322) > TPMS!!!!!
RoryM
Ireland 2008 Range Rover Vogue TDV8 Santorini Black
TPMS!!!!!
Main dealer wont turn off my TPMS.... so bloody frustrating! Big Cry
Post #244650 24th Feb 2014 3:22pm
get an iidtool and do it yourself [and other stuff]
Post #244654 24th Feb 2014 3:31pm
Sandyt
+1 also I use main dealer as have a landrover warranty but always run the diagnostics before it goes in and when it comes back out to see what they should be doing and what they have done Wink and they are not expensive Thumbs Up
Post #244666 24th Feb 2014 5:36pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
What is TPMS??? Seen it mentioned in posts but no mention in my handbook . There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #244706 24th Feb 2014 9:35pm
Googsy
Tyre pressure monitoring system not worth the hassle! Rory as said get yourself an iid tool and say good bye to the dealer Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #244707 24th Feb 2014 9:40pm
rej
Thanks. I don't think I have that do one less thing to go wrong. There is a difference between knowing your sh!t and knowing you're sh!t
Post #244709 24th Feb 2014 9:48pm
RR2008HSE
I'll second all the above. They're a bloody nuisance and I got an IID specifically to turn it off.
It's a gadget with little utility and very expensive parts.
Post #244749 25th Feb 2014 8:13am
also Rory, because the tpms valves corrode when you get the chance replace the tpms valves with normal rubber ones.
Post #244759 25th Feb 2014 9:34am
RoryM
Thanks guys, I kind of assumed I would get this sort of reply. IID tool it is then.
Now, where might a douchebag like myself pick up a cheap one of these and get it changed to my own VIN#.... Whistle
Post #244814 25th Feb 2014 3:25pm
T24RES
A wanted post may help, they seem to fetch in the region of £150 then as long as the model you have is in the same bracket as the sellers (ie:2005-2009) it is £25 for a new licence. If the car is in a different era then its £80 to re-licence. Ian
Post #244820 25th Feb 2014 3:58pm
