![]() | Home > Technical (L322) > Sunroof question |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
wind deflector? ... - .- -.
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3819
Stan's right it is a windeflector, its supposed to be spring mounted though and flick up when you open the sunroof |
| DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 798
ummmm. it didn't !! Better start investigation why. Hope the spring hasn't gone. Just checked Rave, no mention of it or how to remove/repair |
Bit of manual up and downing with a blast of WD 40 and then some grease around the pivot points seems to have done the trick. Be careful though if messing with yours, very cheap and nasty and could easily break. |
