![]() | Home > Technical (L322) > Rear wiper motor - post seal replacement |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
my thoughts are that you might have put it back together incorrectly... ... - .- -.
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
repaired mine done half a wipe of the rear screen and then packed up,scratched head for a bit un plugged it then plugged it back in and it has worked ever since |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
Ah, thank you - that gives me the pick up needed to take it apart again, cheers |
Very oddly - exactly the same experience, took it off, refitted it and the motor fired back into life! Sadly still leaking even with the new washer so new motor ordered…. 4.2 Supercharged Vogue SE |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
When I did mine the first set of screws I used sat slightly too high and jammed the mechanism on reasembly. Might be worth checking yours as you mentioned it was tight when you reassembled too. Smaller headed screws sorted it. 2012 Westminster TDV8 4.4 Indus Silver
