Home > Technical (L322) > upper windscreen trim
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Hi,
I need to replace the rubber exterior upper windscreen finisher on my 2004 TD6 (was deteriorated at the jet carwash and I now have some water sitting under the screen).
Part is DCB500050PMD.
Has anyone done this before? How difficult is it and what should I know?
Thanks
Post #253142 7th Apr 2014 7:57am
from the pic it looks like its a push fit ,
Post #253145 7th Apr 2014 8:33am
L322RR
Thanks,
I hope it is, I hope it's easy to remove.
Post #253146 7th Apr 2014 8:37am
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Be careful with this piece of trim. You may need to remove the A Pillar trims to get a flush fit and the clips that hold these invariably snap in the process. I have had nightmares with windscreen trim following incompetent windscreen fitters who don't know what they're doing. Make sure it sits completely flush or you will be plagued with wind noise and vibrations!
Post #253364 8th Apr 2014 7:25pm
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Autobiography could you elaborate a little please. I recently had my screen cut out due to wind noise, sure enough the glass had parted company from the bonding glue however I still think the top of the screen suffers noise. Any ideas?
Post #253390 8th Apr 2014 9:08pm
Glassman
Technically speaking, the original trim should not have come out so easily. They're slotted onto the glass edge before the windscreen is fitted to the car; there is also a thin line of double sided tape inside the trim recess which helps keep it in place, preventing it from sliding left to right.
Correctly positioned, the trim should effectively be pinched between the glass edge and the rebate, leading up to the roof skin.
It's not an impossible task to fit the trim back in without removing the glass, but I would try by measuring and marking the centre of the trim (and top of the screen) and then slide the L+R ends in first, without taking the A pillar covers off. Then simply work on compressing the rest of the trim in the middle into place.
Do not use an excessive force and definitely no hard tools. If using a plastic filler spreader is not doing it, put the trim in a plastic bag, seal it, and immerse the bag in hot water for a while to soften the trim compound.
Post #253409 8th Apr 2014 11:17pm
L322RR
Thanks Glassman, looks like a hell of a job.
The trim didn't move, it was just a bit damaged, and now I have some mist between the screen and the trim.
Maybe I should just live with it and wait.
Post #253430 9th Apr 2014 7:06am
Autobiography
There should not be any bonding glue. I had this issue when the windscreen company tried to re-use broken trim clips by using glue. Correctly fitted, none of the windscreen trim should need any bonding. This includes top trim, a pillar covers and scuttle panel. Basically you need to watch them like a hawk to check they don't glue anything. Recently had a new windscreen fitted and I requested new trim clips etc from the outset. They are not reusable.
Post #253433 9th Apr 2014 7:35am
Glassman
Nobody is suggesting he should use any type of glue, and you're absolutely right.
I maintain that he shouldn't have to take the A pillar covers off, ergo: no issues with clips, unless the screen is being removed in which case it should be done by a professional.
Post #253441 9th Apr 2014 8:15am
