Home > Technical (L322) > Metallic Rattly noise on hard acceleration 4.2 S/C
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Right, this little problem has reared its head a few days into S/C ownership.
On harder (brisk lets say) acceleration in lower gears my MY07 4.2 S/C makes a very strange noise. It almost sounds like its in the cabin, certainly behind the driver. Its like a metallic rattle, it could even be audio speaker crackle related its such a strange noise. Almost like a "white noise" noise. Ive tried with the stereo of and it made no difference, I have also tried turning the rear fans of just incase its something stuck in a duct touching a fan whilst under acceleration.
Its only apparent in lower gears where acceleration is greatest.
I havn't actually done much experimenting with it just wondering if anyone could give me some pointers.
I'm thinking it could be an exhaust baffle or some sort of heat shield? What do people think? 2005 E60 M5
2006 (MY07) L322 4.2 S/C
2024 i7 xDrive60
2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE.
Post #430495 8th Mar 2017 8:57pm
Maybe the engine pinking?
Post #430522 8th Mar 2017 11:50pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Could be one of the cats is breaking down internally? Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #430541 9th Mar 2017 7:35am
quavey
No i don't think so it's not that sort of noise thankfully. And you would expect it more in higher gears. 2005 E60 M5
2024 i7 xDrive60
Post #430547 9th Mar 2017 8:49am
quavey
That is where I was thinking annoyingly. 2005 E60 M5
2024 i7 xDrive60
Post #430548 9th Mar 2017 8:50am
bishbosh10
Exhaust heat shield? Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #430762 10th Mar 2017 11:24pm
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
From your description , it sounds like the noise is only apparent when the supercharger is really doing its stuff .
But why you would here it behind you I don't know !!!
( btw , if you hear a noise like marbles rattling around in the nose of your supercharger it probobly needs a new coupler .
And they ALL definately need new oil .... these things are supposed to have an oil change , just like our "sealed for life" transmissions !!! Whistle
A snout rebuild kit with new bearings and oil is only around $100 ... )
I'd look at turning all hvac off so the flaps close , and sitting in the back whilst someone else drives to identify where it's coming from .
Cats can normally be heard with front windows down driving close to a wall .
Or tap them by hand or with a rubber mallet to listen for rattles .
My local dealer will replace cats for free up to 10 years old or 85,000 miles .
Mine went at 86 Laughing
Post #435622 22nd Apr 2017 7:48pm
quavey
I dont think its supercharger related to be honest, mainly as it doesn't occur in higher gears. If it were S/C related it would be there in every gear at a certain RPM etc. I had to "make use" of the power plant this weekend a couple of times - dawdling tourists between Glencoe and Loch Lomand required some committed multi vehicle overtakes!
Its still there, intermittent to be honest, I might have just got used to it.
I'm sure its still an exhaust baffle or something like that.
This week's job is to price up a service now we are back from Scotland, I've a few places I'm going to get a quote from and go from there. 2005 E60 M5
2024 i7 xDrive60
Post #435718 23rd Apr 2017 7:49pm
theres a few heat shields under there, in and around the transfer box as well. get under there and tap them all to see if any are loose or catching on something. Its likely to be a heat shield i would think. I had one making a bit of a buzz on mine, couple of mins under it had found it and bent it back into shape. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #435720 23rd Apr 2017 7:56pm
