Home > Technical (L322) > Remote Locking Receiver (photos / diagrams needed)
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Since I fixed my rear washer my remote locking hasn't worked. I originally thought that the keys had just got flat batteries or lost the codes so I fitted new batteries and tried to recode but nothing.
I know that the receiver (or I believe I do) is around the rear spoiler area so I may have inadvertently disconnected something but don't have any idea what parts, cables etc... relate to the locking so would appreciate if anyone has pictures of showing the location of the relevant parts so I can check all are connected properly before I try and recode the keys again.
Thanks in advance for your help There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #254743 16th Apr 2014 5:12pm
rej
Anyone able to help?? There is a difference between knowing your sh!t and knowing you're sh!t
Post #255420 21st Apr 2014 3:28pm
Would this help?
Post #255423 21st Apr 2014 3:54pm
rej
thanks looks like #13 is the only part I could have interfered with now know where to check connections There is a difference between knowing your sh!t and knowing you're sh!t
Post #255424 21st Apr 2014 3:56pm
rej
Nothing obviously loose but disconnected and reconnected box and now I have 4 keys that lock and unlock. Just need to get the 2 new ones cut so I can use them to start the car as well There is a difference between knowing your sh!t and knowing you're sh!t
Post #255430 21st Apr 2014 5:21pm
Possibly just a bit of minor corrosion on the connectors that disconnecting and reconnecting cleared. Thumbs Up
Post #255432 21st Apr 2014 5:35pm
rej
Only problem now is that the radio reception isn't showing the stations so I guess I have to take the rear apart again to check for anything loose radio aerial wise. There is a difference between knowing your sh!t and knowing you're sh!t
Post #255477 21st Apr 2014 9:16pm
Try a hard battery reset sir... A lot less work then removing the rear panels again Thumbs Up
Post #255514 22nd Apr 2014 8:41am
Could be cos you tried re coding the keys and hence have wiped the stations from the memory. Are you getting reception/can you tune it?
Afaik the individual keys remember the settings for that driver and resetting/recoding them has probably wiped all the memorised stations, possibly just need to reprogramme each set of stations to each key.
Just an idea.
I know there was a software update re holding station memories between keys as i had it done on mine. There is nothing that can't be fixed with a hammer😜😜
Post #255520 22nd Apr 2014 9:15am
rej
All sorted (hopefully) driving to work this morning tuned in manually and while in traffic played with autostore etc... and got station names back and all seemed to store OK. Now just have to see if the work when I next get in. Maybe just my short drive round the corner last night wasn't enough to et everything set up. There is a difference between knowing your sh!t and knowing you're sh!t
Post #255534 22nd Apr 2014 10:51am
