![]() | Home > Technical (L322) > All i had left to do was a REMAP |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
I would be surprised if you can run the two in tandem, surely a remap would require a change to the map that exists.
You can but run the risk of A, smoking and B, going too far and exploding things |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7994 ![]() ![]() ![]() |
I'd do one or the other if it was me.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
Bloody hell, run a remap and a box, even if it worked it is likely to blow the turbo - most remaps up the boost pressures and fuelling - I would stay well clear of the box. An engine that's lunched on a turbo is not a pretty sight |
IMO the best thing you can do is get the GBox ECU remapped and blank off the egr and then clear out the inlet manifold from all the gunk thats been built up in it for 10years of recirculated dirty coked up air flowing into it.
A11EXU Member Since: 31 Dec 2013 Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND Posts: 72 ![]() ![]() ![]() |
Its not that being Scottish as you all think i am miserable
If its mpg you want, you may have the wrong map, one of my old RR's a 2006 TD6 used to return a consistent 27 mpg driven hard - she was remapped by JE and would do 60 in under 10s. |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Agree with the above - My TD6 (2004) was remapped - nothing else has been done - no EGR blanking etc and I get 24 round town 29-31 on a motorway run.
Agree - will investigate the remap side and see if i am set for Power
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
mine has been remapped and i removed the cat plus egr blanked and kn filter ,i can get 30-32 0n a run no problem. |
