Home > Maintenance & Mods (L322) > Piano black wrap
Page 3 of 4 <1234>
n1cktdv8
the WHOLE car Shocked !!!!
Mine had all the stock piano parts so I just did a few extra bits...buy a roll thats 450mm wide and maybe only a metre or so...cost's buttons in comparison....
Conor - not done the rear, too awkward to make it look a reasonable job...I am planning a template maybe using some thin paper...if I do (which wont be for a while as am out of the UK for a while) I will post it up Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #256393 26th Apr 2014 7:07pm
Googsy
Big Cry miss you already Craig Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #256402 26th Apr 2014 8:00pm
B3EEE
2005 Range Rover Supercharged 4.2 SC V8 Tangiers Orange
Piano black, sure looks like good ol' gloss black in photos. Mines Piano black and looks different to yours, or is mine another black, has a slight grain in it.  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #256408 26th Apr 2014 9:44pm
If it has a grain to it then yours will be lined oak sir... Look at the link below, does it look like this? http://www.ebay.co.uk/itm/Range-Rover-L322...2c4b9df8b2
Post #256415 26th Apr 2014 10:31pm
B3EEE
Ha ! Thats it, limed oak - looks black. I remember now as I couldn't get limed oak to replaced door arm rests so went for Piano black - so mines a hybrid !!  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Post #256464 27th Apr 2014 12:47pm
n1cktdv8
If the parts are removable I'd suggest painting them. I only used wrap on the bits I couldn't remove. Is this where I put the car details and a bit about myself ?........
Post #264182 9th Jun 2014 2:34pm
Googsy
Your right Nick as good as the wrap looks I haven't been happy knowing that's it's all wrapped. With that in mind I have been busy removing wrap and am now in the process of painting. I have done a few parts including the panel above the upper glovebox all in gloss black with 8 coats of lacquer. I have to say its looks factory with a real mirror finish. It's a lot of work but worth it and I always like to have a little project on the FF. Pictures to follow once completed Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #266648 21st Jun 2014 11:11pm
n1cktdv8
Conor...your a b Censored y nightmare....I now have 5 weeks before hols to do all this on my car Rolling with laughter
How did you get the panel above glove box out....thats the onyl place my wrap has bubbled....like you I have sprayed some bits now and with a mountain of laquer layers it looks Cool Is this where I put the car details and a bit about myself ?........
Post #266649 21st Jun 2014 11:28pm
Googsy
You open glove box remove left vent and you will see it is held in by a single screw remove that and then pull out towards you held in by two clips. I removed the range rover badge and cleaned underneath to remove sticky residue. Don't be tempted to put badge back on until you have fully sprayed panel sanded and compounded and polished Otherwise polish gets under badge ask me how I know Big Cry so had to be done again. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #266650 21st Jun 2014 11:34pm
n1cktdv8
Please see my last post.....
So I bought this air freshener and hung it on the left indicator stalk....and it's removed the topcoat off the steering binnacle....so after stripping them off to see what could be done I now find myself stripping the "wrap" bits off, priming and prepping for some gloss black and laquer then overnight "heat"....
Conor...this is your fault Whistle Is this where I put the car details and a bit about myself ?........
Post #268965 3rd Jul 2014 9:39pm
Googsy
Mmm well after your advice i did the front ashtray. For a simple piece if trim it was a nightmare as i was over confident. I have had to do it twice and although it looks good im still not happy with it. Lacquer needs at least 36 hours before sanding. The journey continues Big Cry Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #269030 4th Jul 2014 8:33am
n1cktdv8
Update....upper glove box panel done, gave the RR badge a tickle of sparkle silver and laquer too...
Also do the steering binnacle after the air freshener problem and it's ok....but I have now hit the wall on piano black....I'm done, it's enough and looks good. Is this where I put the car details and a bit about myself ?........
Post #269435 6th Jul 2014 11:10pm
SteveMFr
Site Sponsor
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #269454 7th Jul 2014 8:15am
 2008 MY Supercharged
Post #269455 7th Jul 2014 8:42am
Googsy
Mines still work in progress have been busy at work so Rangey has taken a back seat.Any pics Nick promise i will have mine soon Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #269483 7th Jul 2014 11:49am
Page 3 of 4 <1234>
