Home > Technical (L322) > Alarm going off
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Alarm going off
Hello fellow L322 enthusiasts! I've got a problem with my alarm going off at regular intervals. It says on my info screen (MY2011) my hood is open and it isn't as I checked and slammed it shut. Now from time to time my hood shows it is open while driving, my dealer sent me a new hood alarm button as he thought it was caused by this, I changed it to no avail as it is still showing open from time to time and this triggers the alarm when parked. Very annoying. Anyone had the same experience and knows what the problem could be (I was thinking the wiring?).
Post #257031 30th Apr 2014 6:00pm
Try putting a blob of chewing gum on the top of the switch plunger, close the bonnet and see what happens. Thumbs Up
Post #257038 30th Apr 2014 6:28pm
disconnect the switch and put the 2 wires together...... ... - .- -.
Post #257039 30th Apr 2014 6:34pm
Watty
Scotland 2017 Range Rover Autobiography SDV8 Santorini Black
This happened to me, ibuilt up the top of the plunger with double sided tape cut into small squares, problem sorted 07 Vogue SE Java Black 3.6 TDV8
Black Leather heated/ cooled seats
Piano black trim deployable side steps
L405 Autiobiography 2017
Santorini Black with black pack
13 L405 4.4 Autobiography
Post #257063 30th Apr 2014 8:08pm
drivesafe
Australia 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi CSK and this is a common problem.
The switch is not being depressed enough.
Try getting one of those self adhesive rubber feet, used on on appliances, and locate the exact spot where the switch touches the bonnet, and fit the rubber foot, job done.
Make sure the surface where you are going to fit the rubber foot is clean, so it stays in place once fitted. 2007 TDV8 Lux
Post #257245 1st May 2014 5:36pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
^ I think he meant 'make sure you CLEAN the surface....' Whistle 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #257250 1st May 2014 5:59pm
drivesafe
Thanks Fill Fat Ray, and post corrected. 2007 TDV8 Lux
Post #257253 1st May 2014 6:40pm
Full Fat Ray
You need a new 'smell checker' sir!!
Regards,
Fill fat Ray Rolling with laughter Rolling with laughter 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #257261 1st May 2014 7:16pm
CSK
Hi guys, I hadn't had the time to thank you yet, busy day! I've put a piece of self-adhesive plastic under the bonnet right above the button and fingers crossed I haven't had a false alarm today. Thumbs Up for your feedback!
Post #257266 1st May 2014 8:08pm
