![]() | Home > In Car Electronics (L322) > antennae for digital hybrid |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
same antennas i believe...mine has digital and the windows look the same as the windows on my old td6 .. ... - .- -.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
The antennas are the same, the hybrid digital tv unit is plug and play. The touchscreen Denso satnavs systems are all compatible with the hybrid tv units, but make sure you get the tv units with the correct part numbers. There are some hybrid units advertised on fleabay which aren't european spec. and they don't work.
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I just swapped connector from the old analogue box to the hybrid box that sits next to it and all works, 2 minute job, aerials etc all the same There is a difference between knowing your sh!t and knowing you're sh!t
kirton Member Since: 24 Jan 2014 Location: Crediton Posts: 50 ![]() ![]() ![]() |
Thanks guys, that is all very helpful. I was finding some of the other threads a bit confusing. I have bought a 2006 Autobiography with RSE and it it seemed a real shame not to keep it up to scratch. |
