Home > In Car Electronics (L322) > Sat Nav time to desination
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
I can't for the life of me work out how to display this. My software seems to be different to that shown in the user guide (and rave)
How do I get the ETA displayed?? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #257410 2nd May 2014 8:29pm
mjdronfield
Is it a mk4 nav ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #257420 2nd May 2014 8:53pm
tymh
erm...??? Shocked Rolling Eyes i'll try to get some screen shots tomorrow. Tym
Post #257429 2nd May 2014 10:09pm
mjdronfield
Does it say DVD on the front of the unit in white ?
The mk4 BMW unit was never fitted to our cars - it has to be retrofitted from a BMW.
Another way to tell - does it have off road navigation as an option on the menu ?
You lose that if you go to the later unit.
The only reason I ask is that I had the same issue, but I have a mk4 sat nav......
http://www.fullfatrr.com/forum/topic15145.html?highlight=arrival
Here is a mk4 unit
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #257432 2nd May 2014 10:18pm
tymh
Just read your other thread and it looks like you had exactly the same problem I have. I *don't* have navcoder and the bwmcable.com site is down. I did find http://bmwcables.co.uk/order.html though...
what do you plug into and where? Do you connect to the ODB2 socket (as I have cable for that) or directly into the DVD or... somewhere else? Tym
Post #257468 3rd May 2014 4:07pm
mjdronfield
I have the blue cable, which was just over £20 if I remember right.
The cable you show will do it, and later cars according to the reading, but it's a bit more expensive.......
You will have to get the full version of navcoder too, but it's not a silly price. Around £20 again I seem to remember.
Have a look on the navcoder site or images on Google and you can see the options you can change etc.
It connects to the obd plug under the dash, and then to a laptop via USB. I use an old dell running xp.
If you are going near Chesterfield any time, you can change your setting with my kit.
Sorry, quick edit, you will need a specific bmw diagnostic cable which will work with navcoder. Standard ones will not. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #257474 3rd May 2014 4:20pm
tymh
Great - thanks for the heads up - bu Censored er my OBDII cable won't work! Big Cry Tym
Post #257476 3rd May 2014 4:24pm
mjdronfield
I have one of these ;
http://www.ebay.co.uk/itm/BMW-Diagnostics-...4ad46228c5
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #257477 3rd May 2014 4:31pm
tymh
Got it - thanks.
Tried my cable and navcoder won't open the port - keeps complaining and offering to inform the developer!
my ODBII cable works normally and I've reset the MIL as it's running a little lean (so it says) perhaps it doesn't like the LPG!! Think it just needs a tweak so will have to book it in with him.
I'll let you know how I get on when the cable arrives Tym
Post #257482 3rd May 2014 4:57pm
tymh
Turned out to need the "arrive at destination" un-ticking... as per your situation.
I don't have off road navigation as an option... Tym
Post #258221 8th May 2014 12:59pm
mjdronfield
Excellent. Don't know why you have to untick it to enable it.........
You will have the later Mk4 DVD based sat nav unit taken from a BMW then.
Much faster due to being DVD and not CD based and you can have a 3D perspective view which you prob already have enabled.
It never had the Off Road Navigation option, like the Land Rover specific firmware on the Mk3, but all that did was allow you to store waypoints on a journey off road so you could come back the same way - as far as I know anyway. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #258225 8th May 2014 1:10pm
