Home > Technical (L322) > Door Handle Dissection
TugRR
A question, as opposed to a "how to" . . .
Any advice from Forum members as to how to remove the plastic recessed knuckle plate from an L322 door handle ?
The whole assembly is off the car (and is in fact a spare).
So far, I've removed the three Torx screws fastening the hinge spring support to the said plate, together with the roll pin for the end of the handle.
I see just replacement handles are available - just can't work out how the blighters come off . . .
Limited physical abuse, lots of verbal abuse & head scratching so far have not worked.
Any ideas, anybody ?
Thumbs Up Where do you go after one of these . . . ?
Post #257457 3rd May 2014 11:45am
TugRR
. . . mmm - as I suspected. Nobody is crazy enough to have attempted this before ! Laughing
Post #257547 4th May 2014 8:49am
give it time Paul, most are out mowing the lawn.. Thumbs Up ... - .- -.
Post #257556 4th May 2014 9:42am
Paul, i have done it in the past but cannot remember how! (a while ago) Post up a couple of pics and that may help me remember Thumbs Up
Post #257561 4th May 2014 10:09am
TugRR
Stan - Laughing - we're at a rugby tournament ALL DAY with jnr
Craig - will do, on the pics. I've looked long & hard three times now - I'm sure I'm missing something obvious ?
Post #257583 4th May 2014 11:35am
TugRR
Well, more head scratching and I have concluded major surgery is involved, ie removing the sprung pin Rolling Eyes
Pivot pin removed . . .
Can see how it's put together, but not taken apart . . .
Spring pivot . . .
As stated before, the handle alone can be bought as a separate part, but it would appear something needs to be sacrificed to replace it. mmm . . .
Post #257927 6th May 2014 5:46pm
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
I was about to pull the trigger on a new set of handles but wondering if the stick on covers or painting may be the way to go.
Post #257957 6th May 2014 9:20pm
johnboyairey
I'm tempted to go for an on-car (with handles pre-pulled and wedged,) a rub down, masking, prime and brunel grey repaint.
as I'm not a fan of the dull matt finish it will be clear laquer on top. I will repaint my step trims also.
maybe I might even take some pics....
Post #257971 6th May 2014 11:04pm
TugRR
. . . . Handles now thoroughly dissected - "How to" with pics coming up soon -
Post #258086 7th May 2014 7:59pm
Flashman
Looking forward to it. My handles and back plates all need colour coding to the car and was thinking of an on the car job. Tom
Current Drive
Previous Drives
Post #258095 7th May 2014 8:47pm
