![]() | Home > Technical (L322) > L322 5.0 SC not starting |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
Lock it up, walk away and come back in 30 mins, if that doesn't work disconnect battery, leave for 30 mins and reconnect - if that doesn't work then call LR Assist |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Have you tried the other key? There is nothing that can't be fixed with a hammer😜😜
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
Locked the car and unlocked much later but still no go. Tried with the two different keys also. Will try and disconnect battery in the morning and see how it goes. |
When you press the brake pedal, do the brake lights light up ?? Since the brake switch needs to be activated for it to start, if that is not working properly the ECU will not start the engine.
Thanks Eugene but I can't get the ignition on and I think you need the ignition for the brake lights to work.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Mince alors! good new, a battery is not that expensive and really easy to swap with the bonnet in "workshop mode".
That would be good news if it is only a battery !! Also good to know if I ever have a similar issue, than battery is what to look for. Maybe replace it anyway next time I get a chance and put a biggun in |
Can confirm it is the battery. Went to pick up a new one from my Land Rover dealer, had it installed by my friendly local garage (Renault service dealer) and it started first time. Must say Renault service is very good, may I dare say better than Land Rover Non Assistance! |
Will you be taking the Aston Angel? |
wife, 2 kids and the luggage ... are you kidding me ? |
Oh, I'll stand a chance of winning the race then! |
