![]() | Home > Technical (L322) > Which transfer box? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Found this which answers ^ that!
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
are you still having trouble
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
These tdv8 RR seem very problematic as much as td6 I think I'm going to hold up on a newer model |
I'm told by the garage that it looks porous - has anyone heard of this? |
Nope, never heard of the casting going porous, i will get them to check it out while its out, im going to ring a tranny specialist tomorrow to find out the gen on the box.
How did you get on? |
Been in today and they replaced the hi/low position sensor as it was leaking from the block connector aparently, anyhow i will check it in a couple of days to see if it has stopped leaking.
Hi mark
I've had another look under mine and I really can't see where its coming from.
i Mark.
