|  | Home > Technical (L322) > door mirrors |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35884    | a quick double tap on the button should do it.. ... - .- -.
|  30th Apr 2014 2:06pm |
| tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90      | I had this problem recently and soon after my battery needed replacing as it wouldn't hold the charge. When the battery was replaced the mirrors fixed its self and worked correctly. So maybe your battery is on its way and causing the mirrors to play up. (Only guessing, from my experience) Range rover td6 54 reg touch screen | ||
|  10th May 2014 4:14pm |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029      | It is a relatively common issue and there are a few fixes. If you do a search on the site you will find them. The double press didn't work for me, I ended up pulling fuses. Good luck.
|  10th May 2014 5:44pm |
| calypso Member Since: 16 Oct 2013 Location: Renfrewshire Posts: 6      | Had the same problem with mirrors out of sync. Double tap worked. Great--- Big thanks for tip. | ||
|  11th May 2014 2:55pm |
| Posting Rules
