![]() | Home > Technical (L322) > TD6 Performance Upgrades |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
I'd say ;
Jmelvinbath Member Since: 12 May 2014 Location: Wimbledon Posts: 16 ![]() ![]() ![]() |
That sounds cool, so in addition to what i've got planned just a free flow air filter? does this effect risk of water getting in from splashes etc when wading?
If you want even more power, Jeremy Fearn fit a kit with a second intercooler, resulting in 250 bhp and 420 torques......
Looks quite good... I'll ring them and find what they can do... Looks like i won't be bothering with the facelift then.
Sorry, posted same time as you - not tuned and higher than that. Not aware of injector changes etc, but as its basically the same engine, it should work.
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Sell it and get a TDV8. |
And then worry about turbo issues instead of gearbox ones ! 2011 Range Rover Vogue SE 4.4 TDV8
Thanks guys, i'll look into the air filters and see if my mate fancies having a look at the engine in more depth as well.
You need to do a new thread telling us about fitting your touchscreen ..........
Very quick summary..
Basically didn't want it in anyway not to look OEM, so when you have it all turned off the only bit you can see is the iPhone dock i built into the coin tray in front of the gear selector |
Nice job! I have a touch screen overlay in my TD6 as well. |
NicolasV Member Since: 02 Mar 2014 Location: Hoogstraten Posts: 6 ![]() ![]() |
Hi james,
I looked at removing the cat, but when I found out it smelled like standing behind a old ice cream van on tick over, I went off the idea....... 2011 Range Rover Vogue SE 4.4 TDV8
