![]() | Home > Maintenance & Mods (L322) > Air Con is STILL NOT WORKING |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
In my experience, a regas only is a false economy.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
^+1 |
It may well be, of course, that ATS do a pressure test first in any case.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
As SKOT says, Air con chaps will not be allowed to let it vent to air. They will prob use a vacuum to get the remaining refrigerant out and then do a leak test.
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
You are all quite correct. ATS do conduct a pressure test first, all being well they will then do an antibacterial flush then a re-gas. |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
Is your air con compressor working as mine does not. I took the under shield off and checkecked and the clutch is not locking up but have not looked into it anymore. |
I haven't looked, I would not know what to look for or what I was looking at. |
I'm not 100%, but I don't think the air con will engage if the gas is low, so the clutch etc could be fine, but the interlocks on the system will stop it engaging. 2011 Range Rover Vogue SE 4.4 TDV8
ERMMMM |
I thank you Sir.
I have re-gassed three Range Rovers at the Halfords Auto Centre and from warm air to perfect VERY COLD aircon working brilliant. My car was done 6 month ago and is still ICE COLD so there were no leaks. Older cars simply run out of gas... |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
My freezer in my garage is 15 years old and it hasn't run out of gas yet.
Three years I would be concerned too!
