![]() | Home > Maintenance & Mods (L322) > L322 bonnet / hood air intake vent - removal |
| Bagus Member Since: 15 Apr 2014 Location: London Posts: 202
The air vent on my bonnet is looking a little sad and I thought I'd remove it and paint it so its nice and black again. However I'm not sure how to remove it. Can it be removed?
It is a straight forward job to remove the bonnet vent. Take care with the clips and washer connections, these tend to get brittle over time, and can easily snap when pressure is applied. Full instructions are in RAVE, but it should be self evident what needs to come apart once you look into it.
IIRC, you don't have to disconnect pipes, simply remove the washer unit from the vent, and leave pipework intact. .
Managed to disconnect the washers and rain sensors and have the grill off.
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
Repainted mine on the TDV8 in a very close to stock colour, very nice and ends up cheaper than this unit.
| Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445
Does anyone know the colour of these on the 2010+ model?
