Home > In Car Electronics (L322) > Sat Nav Radio screen setting when you start your FF
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
My screen for an 02-05 FF always goes to the menu when i start the car so i have to push the right hand button evry time to give me the screen view i like, is this normal or should it remember my last setting ??
Post #262635 1st Jun 2014 7:01pm
mjdronfield
Mine stays at where it was when I turned the car off.
If you have voice control, you can tell it to go to map, as that's where mine normally stays.
If I turn the radio on, it'll change to that...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #262638 1st Jun 2014 7:20pm
Mine goes to the splash screen then switches to the last screen selected with the exception of the tv which if previously used will still need the select button pressed before the picture and sound will display.
Post #262640 1st Jun 2014 7:28pm
netsonic Steve
so i may not have something set right, any ideas...........no voice control unless my wife is in the passenger seat
Post #262648 1st Jun 2014 8:00pm
mjdronfield
Is it the standard mk3 unit, with off road navigation in the menu, or is it a mk4 upgrade ?
Has it always worked that way ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #262650 1st Jun 2014 8:06pm
netsonic Steve
standard
Post #262672 1st Jun 2014 9:46pm
Original equipment: (Usually always listening to radio on switch off) - on start up: splash screen, computer menu, radio menu .
Post #262676 1st Jun 2014 10:16pm
