Home > General > withdrawal symptoms
Andy B
Laughing Laughing Rolling with laughter SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #265289 13th Jun 2014 7:51pm
Glad you got it sorted. Thumbs Up
Post #265290 13th Jun 2014 7:53pm
RR2008HSE
I love Defenders and they're a lot of fun OFF-ROAD. On road Whistle
I went with a friend in his offroading for the weekend. Got back to town, and got in the FFRR to go home. It was like being in the Starship Enterprise at warp speed after the Defender. Mr. Green
Post #265321 13th Jun 2014 11:54pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
withdrawal symptoms - continue
car is now with dealer for a month to resolve some additional issues including a misfire, especially when the car is cold. Other issues are:
- driver's heated seat not working - according to dealer it is now fixed
- intermittent noise from left rear wheel - apparently was the electronic rear diff actuator which was replaced
- as mentioned above - misfire which the dealer is struggling to diagnose. Thus far they've replaced spark plugs, swopped coil packs around, replaced tappet cover gaskets, checked for oil and water leaks without any success of resolving the issue.
However they promised that I'll have my car back on Monday.
In the meantime they've given me a 2014 Freelander diesel to use - nice car but not a fattie. Obviously better than the Defender 90 I had before.
What to do if they cannot resolve the misfire - should I push for engine replacement or look for another car
Post #275061 9th Aug 2014 9:47am
ebajema
The misfire is a strange one, is it always the same cylinder or does it move around. Have the injectors and knock sensors been tested? All the wiring and connectors? Has the engine management ECU been reflashed with the most recent software? Have all the ECUs been reflashed? Has the fuel system been cleaned? Has compression been checked?
Don't give up too soon there are still things to be done that could resolve the problem. MY 2010 5.0 SC Galway green and sand interior!!
Post #275339 11th Aug 2014 4:47pm
vnitos
Eugene
according to the dealer it is the same cylinder (# Cool; however they found a bit of oil on spark plug in cylinder #2. From time to time the engine management light (EML) also come on and stays on until the dealer resets it.
The cost for the repairs is not my worries - as the dealer will carry that. It is just that I miss my car.
Post #275383 11th Aug 2014 7:44pm
vnitos
must be no 8 cylinder
Post #275410 12th Aug 2014 5:08am
vnitos
just got my car back from the dealer. i have an out of town meeting tomorrow - there and back 750kms (470miles) - so hopefully everything's been sorted fully
also have a trip of 800kms (500miles) on Friday
handed the dealer's car back to them with extra 5000kms (3125miles) added to the odometer reading
Post #275644 13th Aug 2014 3:11pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Vnitos...what was the noise from the rear left wheel related to the ETM diff??
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #275645 13th Aug 2014 3:15pm
vnitos
@Paul: the noise was very intermittent, basically once-off and happened very rarely. The dealer's service manager described the noise as "sounded like something fell off the car - I almost $hit myself".
it almost fell as if the brakes were holding on for a bit and then release violently
Post #275648 13th Aug 2014 3:25pm
paulmoran2
Cheers...sounds nasty GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #275651 13th Aug 2014 3:32pm
vnitos
did a trip of 750kms yesterday - can't describe the difference in ride comfort between the Fattie and the Freelander loaner I had.
Car drove beautifully - only issue was that EML came back on - however I had the cats removed and the code given indicates that could be the reason
Post #275867 15th Aug 2014 5:46am
ebajema
Well that sounds promising !!! I hope it keeps on going well from now on Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #275897 15th Aug 2014 10:34am
If you have the cats removed and it brings on the EML try spacing the lambda sensors out (away using washers or alike) that usually solves the issue Thumbs Up
Post #275983 15th Aug 2014 8:36pm
