![]() | Home > Maintenance & Mods (L322) > Calipers? Brakes? Front wheel squeal |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
could be just a build up of brake dust...normally a hard sharp stab on the brakes clears the squeal. ... - .- -.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Sticking caliper |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8797 ![]() ![]() ![]() |
Could be pads sticking in carrier.... I'd get them stripped to find out the issue...
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
When you hear the noise i take it if you gently apply the brakes the noise goes....
Thanks all for quick and plentiful replies.
Right it's still doing it but for now, only say once on a short 3 mile round trip 10 minute journey.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Maybe a stone lodged there ?
Wheel off in the morning to check that Tug and I'll give it all a good clean.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Mine did this a few months ago and I thought it was the wrong pads but no took it in and everything was ok but still made the squeal with mine it may have been a slight lip on the disc but it wasn't obvious and now it has resolved itself I think it was a bit of rust on the edge of the nearside front , sorry if this doesn't make sense but hope it helps - I would persevere and see if it goes away |
Brand new disc and pads on this one Sandy... reassuring though... I don't think its anything serious... the fitter of the discs and pads didn't use the grease supplied with the kit (used grease that his garage normally uses) and I'm now wondering if it's something to do with the type or not enough grease having been used at the point of fitting.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
I was going to suggest a lack of grease Ryan. Whenever I replace mine, I use either copper slip, or the new ceramic stuff that ECP sell. Got - 2017 SDV8 Autobiography in Loire Blue
So it did it a few times today and the squeak seemed to come on when driving slowly around town accel from speeds 20 up to 30 mph and it did seem to come on when the steering wheel was turning more to the left whilst driving along... A light touch of the brakes seemed to stop it today. Again, wheels not overheating and no obvious hotspots. Noise now starting to remind of a squeaky wheelbarrow, if that makes sense? |
Sounds exactly like mine was . If I did lots of town driving = squeal do a run on the motorway and it was gone I think the discs had a slight lip and maybe the pads were just catching the lip but like you a slight dab on the brakes and it vanished. You said that you had knew Brembo discs and pads? so bit confused unless the pads weren't oem?? |
Muttley Member Since: 21 Apr 2013 Location: Heathrow Posts: 536 ![]() ![]() ![]() |
Been getting funny noises myself and I do mostly short journeys |
