Home > Maintenance & Mods (L322) > Calipers? Brakes? Front wheel squeal
pld118
250 mile journey today and not a squeak! Shocked
Post #265586 15th Jun 2014 8:16pm
Prop
Price of a tank of fuel to fix a squeal Rolling with laughter . Mind you mine squeals after long journeys and before even after new LR pads and discs on the front so not sure what the cure is, weird thing is mine comes and goes. Big Cry
Post #265596 15th Jun 2014 9:15pm
sounds like the mouse has made a new home some where.. Mr. Green
stone fallen out maybe? ... - .- -.
Post #265604 15th Jun 2014 9:45pm
pld118
It'll be back!
Post #265607 15th Jun 2014 9:52pm
Sandyt
Funnily enough mine came back on the weekend but was in London last week so all stop start now today back upon Evesham long journey and gone. Maybe my mouse doesn't like the country Laughing
Post #265721 16th Jun 2014 3:37pm
pld118
Whilst fitting new rear calipers, discs and pads today the mechanic who fitted the fronts a few months ago, checked this out and said that the fronts were quite dusty and he blew air through them but could find nothing untoward... And I drive off, only for the intermittent squeak to return. Arghhh!
Post #266642 21st Jun 2014 10:23pm
Bit more copper grease needed, probably...... There is nothing that can't be fixed with a hammer😜😜
Post #266644 21st Jun 2014 10:28pm
pld118
Think you're maybe right there NMJ. He used his own grease when fitting the fronts. Next step is to have the front pads regreased!
Post #266646 21st Jun 2014 10:38pm
The squealing is normally the pads resonating in the caliper. There is a bit of play obviously in the fitment of the pads to allow them to move, but basically they need well greasing, little dab on the pins too and this should cure the squeal.
Brembos are pretty reliable bits of kit and its unlikely that the calipers are at fault, hopefully just a matter of re greasing them properly and when the pads have bedded in fully then all should be well. There is nothing that can't be fixed with a hammer😜😜
Post #266647 21st Jun 2014 10:48pm
pld118
Well, yesterday and today, I removed the front wheels and simply cleaned visible parts such as the calipers, the smart dark grey Brembo hub face and the disc faces/ disc rim edges.
I actually used Tardis on a microfibre cloth, the slightgtest dab of Mr Muscle sprayed on a microfibre cloth and then washed the areas down with car shampoo dabbed on a damp microfibre sponge... And I also cleaned the inner rims of the alloys properly too Mr. Green
Dare, I say, since cleaning the components on the front passenger wheel side yesterday, no squeal, no noise... Sssh
Anyway, without removing the entire caliper I will also remove, clean off and and re grease the Brembo pads with a good helping of copper grease... If all that doesn't keep the squeal at bay, I'll get the calipers off too.
So far so good Thumbs Up
Post #267288 25th Jun 2014 12:47pm
