![]() | Home > Maintenance & Mods (L322) > OIL LEAK!! |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Don't bring it my house with oil leaking all over my oil free drive. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16387 ![]() ![]() ![]() |
Check the oil filter reservoir as they often spring a leak (if the seals are not changed during servicing) and it drips down that side of the diff |
Plumber cae Member Since: 19 Jun 2014 Location: Blackwood Posts: 21 ![]() ![]() ![]() |
Will lift it up after work tomorrow, will check that reservoir tomorrow thanks for the tip!! Was thinking about changing the oil on the weekend anyway and I now know the perfect place to do it Jayboy!! |
Forgot to mention that I changed out the old style crankcase breather last week for the updated style, wether this has anything to do with it, I doubt it as it's on the opposite side to the leak. |
Got a pic of your rr then Jayboy? |
Have a look in my gallery |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
i have a 2002 TD6 and i have a minor leak as you describe which i think is the seal between the sump and diff, £8 for the seal bitch to change so as i dont get any drips just a bit of oil stain around the diff ive not tackled it just wash it off every few months................it leaks less when ive done an engine oil change |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
And don't go under your car in off road height without putting an axle stand or two in place, just in case!
Thanks all, will clean it up tomorrow and have a proper look with the axle stands !!! Will keep you posted! |
Not an easy fix...... Defiantly the oil sum seal!! Anyone done this before?? Or any advice? Thanks |
