Home > Maintenance & Mods (L322) > Handbrake cable replacement L322
Semperfidlas
England 2005 Range Rover HSE Td6 Zambezi Silver
Hello
Has anyone replaced both handbrake cables on a L322 and if so can you tell me or direct me to a previous post please
Post #267277 25th Jun 2014 12:01pm
http://www.fullfatrr.com/wiki/Handbrake_cable_replacement
Post #267285 25th Jun 2014 12:40pm
Semperfidlas
L322 handbrake cable replacement
Thanks very much for that sound easy enough I guess the pin mentioned is accessed from the rear centre consul cover insert
Post #267296 25th Jun 2014 2:13pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Did mine a few months ago. Only comments are:
1. Messing around under the centre console fiddle. Lost a snap on socket in there somewhere.
2. The handbrake cable connector retainer at the hub was completely seized. Chopped the nipple off the end of the cable so I could pull it through then set to work with drifts, hammers and chisels to unstick the the flange at the back.
Other than that, relatively straightforward.
Handbrake still rubbish. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #267416 26th Jun 2014 8:17am
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
I am amazed that someone has not come up with a handbrake mod for the old L322, the issue seems to centre around the self adjuster under the console because lets face it handbrake technology has not change much so why is the L322 handbrake so ineffective,............mine improved with new rear discs and handbrake shoes but its still has to be pulled far too high with far to many clicks to hold the car.................
Post #267461 26th Jun 2014 2:35pm
Semperfidlas
L322 Hand brake Cable replace
Hello RR Blue
Thanks for your comments when you were inside the console is the location obvious to put the pin once you have compressed the self adjust spring and is it easy to get at, I guess the rest is straight forward enough.
Post #267837 28th Jun 2014 5:31pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
The manual says to tighten up the adjusters then back off the 3 clicks, I backed mine off just enough for the disc to rotate (one, maybe two clicks) This gives me a workable handbrake.
Post #267851 28th Jun 2014 6:33pm
RRBlue
Re: L322 Hand brake Cable replace
Unnecessary quote removed
I did not need to do the compression/pin thing. I was able to work the cable heads out of the retainers manually. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #267889 28th Jun 2014 10:08pm
