Home > Maintenance & Mods (L322) > Hate electrics
mudknight
2003 Range Rover Vogue Td6 Java Black
Hate electrics
Hi , having trouble with rear wiper and high level brake light , trying to check if I have power going to tailgate , can't seem to find the fuse ,, or is there a relay I should be checking ?
Post #268305 1st Jul 2014 7:55am
The chances are your two faults are unrelated unless you have a bad earth connection.
Open the upper tailgate and have a look at the two earth points, they are on the tailgate hinges, should be in clean rust free condition. For the wiper check Fuse 10 20A on the rear fuse board in the drivers side compartment in the boot, the fuses are numbered from L to R looking at them.
The high level brake light has possibly just failed due to corrosion caused by water ingress, not uncommon I believe.
No relays anywhere.
Post #268315 1st Jul 2014 9:02am
mudknight
Thanks very much , sorted those two out ,, next all cigaret sockets stopped working , checked fuse in boot and that's ok , any ideas ??
Post #268348 1st Jul 2014 1:14pm
I had a similar problem when I "accidentally" shorted out the connections in the rear 12v supply. Checked every fuse, all were fine, but still no power.
Left it overnight and lo and behold, it worked again!
I guess the fuse fairy must have paid a visit..... Rolling Eyes Got - 2017 SDV8 Autobiography in Loire Blue
Post #268351 1st Jul 2014 1:21pm
mudknight
How many fuses are there for the cigaret lighters ? As I can only find the one in the boot
Post #268379 1st Jul 2014 3:50pm
ebajema
There is a cig lighter fuse in the front as well, can't remember which one exactly but better check Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #268381 1st Jul 2014 4:07pm
Fuses 1 and 7 on the rear fuse board both 20A depending how your car is wired.... there's two options.
No fuses on front fuse board.
Post #268382 1st Jul 2014 4:10pm
mudknight
May be I should have also said she is a 2003 TD6 ,,
Post #268515 2nd Jul 2014 8:24am
The above applies to your car. Thumbs Up
The cigarette sockets and accessory sockets seem to vary as to how they function.
Some are ignition controlled some aren't.
Post #268548 2nd Jul 2014 11:28am
