Home > Technical (L322) > Front windshield wiper park position switch
Westminster_Bri
The Part number you need for a 2011 is LR035813 and thats the whole linkage - you cannot get the motor separately - I had the last one from Plymouth I believe. A new one (if you can find it) is not cheap either at £265 +VAT!
The hardest part about doing the job is removing the wipers! They have been on there a long time and the two metal types have reacted to each other! I used a wiper puller but that alone wasn't enough... some brute force and ignorance was required with a hammer to get them loose... Scary so close to the windscreen! But they do come off eventually.
Other than that, put the bonnet in the service mode (with the locks) and remove the scuttle panel. There are four bolts that attach the linkage to the bulkhead. I also released the top of the air inlet manifold and brought that forward out the way to allow for the hands to get into the bolts...
Aside from the wipers, not technically challenging and is about a 30 min job
Bri
Post #628547 13th Apr 2022 10:55am
bishbosh10
It is very straightforward to swap the motor alone. Much harder to change the linkage too. There’s a good write up on here on how to do it.
I seem to have been lucky so far with my second hand motor….if that’s not the kiss of death then I don’t know what is Laughing Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #628623 13th Apr 2022 8:09pm
drphilgarner
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
Now on my 3rd wiper motor replacement to try and fix this, the latest one is Chinese copy that fits an E39 (direct fit for L322). Still the same.
Swapped the relays in the fuse box, still the same.
Final thing I am trying now is a battery reset. If that doesn't work I am out of ideas.
My wipers work fine, but stop in the vertical position.
Post #680886 21st Dec 2023 12:56pm
drphilgarner
Well now I'm really confused. Battery reset didn't do anything.
Hail mary, I took the linkage of the spline, laid the wipers down and reconnected. Now fixed. Shocked 2011 4.4 TDV8 Vogue
Post #680888 21st Dec 2023 2:18pm
V8rumbler
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Ipanema Sand
I would not bother with Chinese stuff 2007 Vogue TDV8 in Stornoway Grey with Jet interior NOW SOLD
2011 (12MY) 5.0 S/C AUTOBIOGRAPHY ipanemaSand with Jet Interior
Post #680891 21st Dec 2023 2:32pm
urquattrogus
We have this problem, LR035813 is on backorder for a month or so now.
Can anyone help?
I guess we will have to find a used one!
Post #689753 2nd Apr 2024 4:44pm
drphilgarner
Just buy a used E39 one on eBay. Easy to fit. 2011 4.4 TDV8 Vogue
Post #689768 2nd Apr 2024 6:45pm
