![]() | Home > Technical (L322) > Engine system failure |
1959terry Member Since: 28 Apr 2014 Location: London Posts: 128 ![]() ![]() ![]() |
I was getting the same fault alarm when I started from cold. I took it to the garage and they put it on the computer which showed code P132E turbo boost control B performance. They cleared the fault and it has only come back once in the last month. When I googled the fault code mine appears to be the turbo actuator which was sticking and apparently they can be sprayed with wd40 or similar to help.
Turbo related is my guess so above is relevant |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1863 ![]() ![]() |
Turbo actuator sticking, or a split turbo hose. Both very common |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8109 ![]() ![]() ![]() |
Any black smoke ?
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
No black smoke and it has not re occurred so I think sticking actuator, I don't think it had been over 3500rpm much |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
Being someone who already had both of them....
