Home > Technical (L322) > Does a new instrument cluster need programming to the car? |
I don't know but are they expensive and is it hard to replace ? 2008 MY Supercharged
26th Jul 2014 3:29am |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
Yes it does |
26th Jul 2014 5:49am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
If its the hole assembly, speedo , rev counter etc then yes, if just the ribbon for the pixles then no. If it dont work.......burn it!
26th Jul 2014 6:31am |
Yes it has to be programmed with your VIN, and cannot be re-programmed into another car (i.e. they have no second hand value... Forum members take note ) |
26th Jul 2014 6:46am |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 |
Hi all, I bought a second hand one for my 02 TD6, and it worked fine, displayed mileage was from the car it came from, otherwise was fine, I found it straight forward to fit. |
26th Jul 2014 8:42am |
Nickatvirgin Member Since: 27 Feb 2014 Location: Hambledon, surrey Posts: 1 |
Hi All,
1st Oct 2014 1:58pm |
