Home > Technical (L322) > Yet another efing problem vibration through car :update
Page 2 of 4 <1234>
Thats your problem I believe. New Discs at the front.
Post #277141 22nd Aug 2014 5:23pm
...and thats the start of the disc disintegrating!! ... - .- -.
Post #277145 22nd Aug 2014 6:06pm
JESUS CHRIST!!!!!
I wouldn't risk driving that to the end of the road my friend! To say your lucky i think would be an understatement! Shocked Shocked Shocked
Post #277152 22nd Aug 2014 6:54pm
Shocked Wow... When you zoom in you can see the crack moving away from the missing chunk... As above.. Do not drive the car like that... Previously..
Post #277154 22nd Aug 2014 7:29pm
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
well parts ordered from euro car parts delivery on Tuesday
need to use car to get to work sun and mon so will be taking it easy 12 mile round trip all 30mph roads will sort it tues or weds.
hope this is the cause of vibration have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277167 22nd Aug 2014 9:24pm
Given the state of that disc I'd be getting a taxi Sunday and Monday. Wink
Post #277173 22nd Aug 2014 9:45pm
You slam on for a child walking out in front of you and it will probably shatter, no brakes, no child, serious damage to the FF and no insurance as you have posted a picture of it on a public forum....
If it just shatters whilst your driving it will do all sorts of damage to the hub, wheel, driveshaft, suspension arms etc
Take a cab..... it's just not worth the risk...... Pete
-Click here for Thread-
Post #277174 22nd Aug 2014 9:52pm
Get a lift or take a cab my friend... Like i said above! I would NOT drive that 100yds to the end of my road!!!
Post #277175 22nd Aug 2014 9:54pm
trainmanone
good points guys, going to phone ecp in morning and try to cancel order .will get a lift to epc in Trafford park and get parts tomorrow. Thumbs Up
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277176 22nd Aug 2014 9:59pm
Post #277177 22nd Aug 2014 10:01pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
100% agree....the disc could let go at any point. At best you do damage to your car, at worst you plough into a group of kids at the roadside....then Mr Big on Prison H block will own your choc hole for 10yrs when you go down...not worth it. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #277179 22nd Aug 2014 10:02pm
trainmanone
right thanks for opening my eyes guys going to get one disc tomorrow and fit it then when the others come will do other side ,I know will prob be an imbalance in front brakes but will only be for a few days better than driving like it is.
lets hope this is the cause of the vibration ,what do you guys think???
Post #277183 22nd Aug 2014 10:30pm
If I had to guess I'd say you should be able to feel that.....
Being wrong is always an option though....
Don't forget cleanliness is critical when changing discs, the surfaces that mount together should be spotless, remember to remove the transit coating from the disc.
Good luck Pete
Post #277187 23rd Aug 2014 12:30am
trainmanone
Well guys new disc fitted And guess what still got vibration at 55-65 mph!!!!!
Got bottom control arm going to fit later but had pry bar on it no play but try every thing before condem torque converter
There is movement when you push top of tyre that's why going to do control arm
Getting very Censored off with it now have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #277232 23rd Aug 2014 3:10pm
Discotigger
Just a thought, but have you checked that the wheel is seating properly on the hub, i.e. flat and square on the hub? I had a judder in my steering at 55-70mph after getting new tyres fitted, thought it was an unbalanced tyre, but when I tried to take the front passenger wheel off I had to fight to remove it. It turned out that the hub cup had been deformed slightly when the wheel bearing was replaced and the cup was stopping the wheel from seating flat against the disk hub face. I had to file down and round the cup off and smooth out the inside of the wheel recess (the round hole through the centre of the wheel on the inside of the seating face) to ensure the wheel sat squarely on the hub. Judder sorted.
Post #277233 23rd Aug 2014 3:22pm
Page 2 of 4 <1234>
