![]() | Home > Technical (L322) > Yet another efing problem vibration through car :update |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
How much movement in mm is there top to bottom of tyre, at the tyre edge?? Pete
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
Hard to tell poss 2-4 mm not much more and that's with car on ground you can feel movement but can't see where it's coming from.
the vibration can be felt through the car not so much through the steering wheel although there is a slight feel.
That's a difficult question, wheel bearings usually get worse when you turn one way or another....
hi Pete yes was getting vibration at 55 -65 ish on long left hand bends, but defo movement in n/s wheel when you push top of tyre there's a thud not loud more feel the thud if you know what I mean ,like when you put wheel on hub have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
Is the vibration through the steering wheel or through the car, i.e does the steering wheel shake or does your seat shake!!?? Pete
Have posted that above mainly through seat and floor now but originally through the steering wheel . Going to change bottom arm tomorrow for a known good one and see how that goes have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
I know you have already had them done but get the wheels balanced again, I have had this more than once that they don't do them properly, if they don't get pulled up square on the machine then they will be wrong, take it somewhere else and ask them to check them without removing the weights that are on there and see how far they are out, anything over 20grams, ask them to re balance them. I find small independants tent to help more if you explain why....
hi Pete,
Yep.... that doesn't seem an easy one, think I'd just start replacing stuff as well.... just start with the cheapest...
going to replace n/s control arms it had the ball joint done three weeks ago so know for sure the n/s will be newly done se where we go from there
just found this on the net,
hi gang having sat and thought about it for a while ,now thinking cv joint and wheel bearing ,here's the reasoning behind it.
Well it shouldn't click, even if it isn't loud....
that's what im saying its a slight click consistent withn what speed im doing same on full lock left and right.
