Home > Maintenance & Mods (L322) > Drivers door not unlocking |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
maybe dis-connect battery and hope the mechanism resets itself.. ... - .- -.
6th Aug 2014 8:37pm |
You could try prising the collar round the door "pop-up" button up and off, gripping the button with a pair of long nose pliers, pulling it up and at the same time pulling on the internal door handle as in trying to open the door. I believe this has worked for people in the past.
6th Aug 2014 8:39pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Pop up button working ok, just disco 'd battery, was working perfect earlier on , must have loosened something . Might have to call international rescue ! |
6th Aug 2014 9:12pm |
Removed the window trim ,can see the mechanism ok, cable still connected ok , just tge lock not being pulled off the latch , if anyone knows how to get the lock disengaged , please pm me! |
6th Aug 2014 10:11pm |
Might need this
6th Aug 2014 11:35pm |
Is that for a reaming john ? |
6th Aug 2014 11:37pm |
i think there is a cam or sorts in the lock that might be jammed or in the wrong position, if it is that how to get to it will be a problem..
7th Aug 2014 9:14am |
Yes, tried the key mate, trying to force it right now, might have to be a new door card if this fails.... |
7th Aug 2014 9:21am |
Well door opened, I hadn't seated the top of the cable properly which wouldn't allow enough pull on the cable. Apart from a very slightly bent door card, all well. For the next week or so no doubt! |
7th Aug 2014 10:40am |
glad its sorted and apology accepted ... - .- -.
7th Aug 2014 12:30pm |
