Home > Technical (L322) > L322 - 2 electrical problems - related??
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Hi
My car developed a fault with the driver's door. None of the electrics, except the suspension lowering one work. Can't open the windows from it, and the central locking doesn't work.
I took out and checked every fuse in both boxes (except the airbags one) and they're all OK.
Now I have air suspension failure! Shocked
HELP! Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #275368 11th Aug 2014 5:58pm
To clear the suspension fault try starting the engine and then turning the steering wheel to full lock both ways.
Post #275370 11th Aug 2014 6:14pm
tymh
Genius!
Now, why didn't *I* think of doing that? Rolling Eyes Where on earth is that documented?? Confused Tym
Post #275371 11th Aug 2014 6:22pm
Pulling the fuse for the air suspension is the same as disconnecting the battery. Steering lock to lock is the standard solution for resetting the steering sensor after a battery disconnection. An out of position steering sensor inhibits the air suspension.
I think you will remember that. Thumbs Up Laughing
Post #275372 11th Aug 2014 6:27pm
Others have also reported problems with the wiring running to the door becoming corroded (mainly left hand side though). Worth checking the wires back in the A post area. .
Post #275375 11th Aug 2014 6:36pm
Just a thought, does the central locking work using the key in the drivers door?
Post #275376 11th Aug 2014 6:42pm
tymh
No. It just locks the driver's door. The central locking locks all the other doors... Tym
Post #275378 11th Aug 2014 7:07pm
tymh
Yup! That one's stored safely! Very Happy Tym
Post #275379 11th Aug 2014 7:09pm
tymh
SOLVED IT!!!
Goodness knows how this happened but... whilst I was checking all the fuses, it would appear that fuse 11 was never put back!!! ::ahem:: put a new fuse in and it's all working again. Shocked Rolling Eyes Rolling with laughter Tym
Post #275939 15th Aug 2014 3:22pm
Ooops Exclamation Wink
Post #275980 15th Aug 2014 8:14pm
We've all been there Laughing .
Post #276010 15th Aug 2014 10:08pm
