Home > Technical (L322) > Adaptive light module
mk1paul
United Kingdom 2015 Range Rover Autobiography SDV8 Causeway Grey
Hi guys
I think my AFS module has failed - no dash warning lights but no "dance" on startup and no cornering.
The module is listed as YWC500322.
Have found a module that is YWC500320 and also another at YWC500323.
Are these the same? Just differnet numbers for different suppliers?
Cheers
Post #276512 19th Aug 2014 4:30pm
give ducky dan a pm , he might throw some light on this... ... - .- -.
Post #276514 19th Aug 2014 4:40pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Do you know for sure that you have the adaptive lights on your vehicle.
I have the additional ballasts and side bulbs in my lights and I get a yellow warning light for the adaptive lights when I first turn the key but never seen any evidence that they actually come on (some signs of surround melting from previous owner). Also never seen the "dance" on start up but no faults related to lights There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #276899 21st Aug 2014 12:42pm
mk1paul
Hi
It is a 2005 4.2 supercharged so I thought they were standard?
I do not have a warning light on the dash - the xenons cornering just don't work and don't dance!
Post #277121 22nd Aug 2014 3:55pm
i gather your headlights are like the diagram with the cornering bulb [number 5] in it,
this is from the WM,
Post #277127 22nd Aug 2014 4:13pm
mk1paul
Yes that's right.
The previous owner said they used to corner but stopped about a year ago
Post #277130 22nd Aug 2014 4:23pm
sounds like you need to get some diagnostics done on it..might be worth investing in an iidtool which will allow you to get the codes and do loads of other stuff as well.. ... - .- -.
Post #277133 22nd Aug 2014 4:30pm
mk1paul
I wondered if it was just the AFS module needs replacing.
It does not come as a fault on the dash - I disconnected and it still did not register a fault.
Have there been cases where the AFS module has failed but does not give a fault code.
Post #277134 22nd Aug 2014 4:32pm
rej
Exactly the same as mine. Given up as they work as normal lights and no ideas on how to fix or even confirm tha they are wired up and not just replacement lghts from another FF There is a difference between knowing your sh!t and knowing you're sh!t
Post #277140 22nd Aug 2014 5:14pm
