![]() | Home > Maintenance & Mods (L322) > Reverse camera replacement |
davidjpowell Member Since: 11 May 2014 Location: Doncaster Posts: 111 ![]() ![]() ![]() |
The reverse camera on our FFRR died. Found this chap on da bay who,has installed an upgraded camera in the same housing. Better picture and substantially less costly then replacing with oem.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35836 ![]() ![]() |
£160!!!...a bit steep me thinks. |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
That looks very good! Mine is sometimes intermittent, so I might just try this. Did you go there or did you send your old one?
I went there as I was in the area. Took about 30 minutes.
Taking it out looked pretty straightforward.
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
he's doing it a bit cheaper here http://www.ebay.co.uk/itm/Landrover-L322-F...4ada58e4fc |
That's apparently just a replacement camera mounted next to the existing....
Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83 ![]() ![]() ![]() |
I'm wondering if they can upgrade it to a DayNight / Infrared LED style camera??
