Home > Technical (L322) > Steering wheel height adjustment problem
Turnover
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I'm having a problem with the height adjustment on my FF. It is if it doesn't know where it is. When it starts it will move into a random position. When I get out it may move to the exit position but the motor carries on regardless. Equally I have got in it and it will motor down to the lowest position possible which is impossible to drive with. I have to switch the ignition off and on again and then move it up by the stick.
Any idea's
Cheers
Chris 2007 Range Rover Supercharged in Zermatt Silver with Jet Leather
Post #277124 22nd Aug 2014 4:01pm
There is a fix for this on the forum somewhere, requires parts and labour!
Suggest for now you set the right position and turn it off! .
Post #277125 22nd Aug 2014 4:11pm
get an iidtool and switch it off.. ... - .- -.
Post #277128 22nd Aug 2014 4:14pm
Weegie
There is information here: http://www.rangerovers.net/repairdetails/s...troduction
But, as Stan says, switch it off.
PS. Hope it's OK to post a link to elsewhere. John
GAP iiD BT-Sold
Post #277129 22nd Aug 2014 4:17pm
Link on turning off
http://www.fullfatrr.com/forum/topic21545....ring+wheel
A few links on problem
http://www.fullfatrr.com/forum/topic19396....ring+wheel
http://www.fullfatrr.com/forum/post107479.html#107479 .
Post #277132 22nd Aug 2014 4:27pm
