Home > Technical (L322) > Electrical gremlins? Help... |
All points to battery/voltage as you say. Alternator OK?
27th Aug 2014 9:23pm |
gav Member Since: 03 Jan 2014 Location: Hertfordshire Posts: 37 |
Any way to check the alternator or do I need a volt meter?
27th Aug 2014 10:17pm |
psgk Member Since: 18 May 2011 Location: Chelmsford, Essex, United Kingdom Posts: 47 |
I had similar problems last year with the Air Suspension, Passenger Mirror not dipping on reverse, Steering Wheel not adjusting on turning off the ignition etc with my MY2002 Vogue.
28th Aug 2014 1:58pm |
This could be it as the k bus has a fault on the iid tool. Waiting to hear back from gap team now.
28th Aug 2014 2:14pm |
Hello gav,
29th Aug 2014 8:34am |
Well that doesn't sound too painful. I got a fantastic in depth response from Patrick at gapteam for finding the fault. I tried a hard reset which didn't help. Next I will check all fuses and the headlight ecus.
29th Aug 2014 12:13pm |
Here is an update:
6th Sep 2014 10:01pm |
Get the garage to check for water damage to the headlight levelling ECU, it's located at low level on the passenger side outer side panel near the floor. |
6th Sep 2014 10:10pm |
That sounds like the perfect culprit as it was a suspect all along! thanks |
6th Sep 2014 10:14pm |
Update:
2nd Oct 2014 6:00pm |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 137 |
Delighted to hear your sorted. Two questions, how long since the new LCM was fitted and can I please have an idea of cost of the module?
2nd Oct 2014 8:26pm |
Fitted today. Only done 30 miles so far. Cost of £281 plus vat for the unit and about £180 labour including investigations. |
2nd Oct 2014 8:40pm |
Thanks Gav. Can you please report back with an update in a few weeks?
2nd Oct 2014 9:11pm |
Update after a few months - no further problems *touch wood* |
6th Apr 2015 7:54pm |
