![]() | Home > Technical (L322) > New owner with a load of problems to diagnose |
| PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190
Hi guys, I'm a new FFRR owner since yesterday.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Hi and welcome.
Welcome to the cruel world of FFRR ownership! |
^^^^ see what I mean (ECU chains) |
| nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560
The engine oil leaks are either the rocker cover gaskets or the PCV hoses - lift the plastic engine cover off and towards the back there are some rubber pipes running across the top of the engine - these deterioate and turn to mashed sponge - if they are gone then you will be leaking oil down the back of the engine as it will be a fine misty spray of warm oil. Current Fleet:-
Ok a little update on the RR, I has a good look at it Sunday & you can see it's had work done as the front engine cover has been removed. The problem is the cowboy that did the work must have used the old gasket as there is sealer all round the gasket, that looks to be one place the oil is leaking from. The other is one of the breather pipes on the top at the back of the engine wasn't even connected! |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
That pipe at the back could have blown off because the PCV valve is bunged up... this causes crankcase pressure and lots of leaks, there is a how to in the Wiki..... Pete
| hex Member Since: 22 Jun 2014 Location: coventry Posts: 108
Paul what part of Warwickshire you in may be able to help with the fault reading and clearing . |
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
hi
I'm in Coventry hex.
Me to and the odd thing is I am paulm as well lol
| babagee Member Since: 15 Feb 2015 Location: Somewhere between St. Helens & Kazakhstan Posts: 142
This is what I love about these forums - the collective knowledge and the willingness to help fellow owners
Yes Ian, that's what I love about these forums too. The sense of community & willingness to help, Land Rover forums are top of the list for this too |
