Home > In Car Electronics (L322) > USB Audio Connection FFRR 2006.
Arkle
Is there a way to connect my USB stick to the audio system on my 2006 4.2SC?
TIA.
Paul.
Post #283031 27th Sep 2014 1:25am
Not that I know of - but I think you can burn a MP3 files onto a CD - do you still have the handbook ?
Post #283044 27th Sep 2014 9:21am
http://www.fullfatrr.com/forum/topic19857....audio+ipod
Any good sir?
Post #283046 27th Sep 2014 9:44am
Arkle
Thanks, Alistair. Yes I still have the handbook.
Post #283061 27th Sep 2014 10:29am
Arkle
Thanks for the link, Craig.
Post #283062 27th Sep 2014 10:29am
You have to use the correct folder structure to make the MP3 CD's work.
I used to have an iPod with a cable connected to the aux inputs in the back
I then upgraded & fitted the £500 LR iPod interface - which is better, but IMHO not £500 worth
If I was doing it again, I'd stick with the cable.
Do you have an Aux input anywhere - mine was in the back of the armrest
Post #283067 27th Sep 2014 10:41am
Post #283066 27th Sep 2014 10:41am
Arkle
Not sure where the Aux input is yet, but I'll take a look. Thanks for the reply. Thumbs Up
Post #283071 27th Sep 2014 11:18am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
You only get an aux input if you have the RSE (rear seat entertainment) package on this year of vehicle (min'e a 56 plate without RSE and I don't have an aux input, but the MPO3 CD's work well Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #283113 27th Sep 2014 4:40pm
Arkle
Ah! I have RSE. Will the port be in the N/S rear panel?
Thanks. Thumbs Up
Post #283115 27th Sep 2014 4:47pm
If it's factory rse then it will be under the flap below the rear vents, in the back of the centre cubby. There is nothing that can't be fixed with a hammer😜😜
Post #283118 27th Sep 2014 4:56pm
Arkle
Thanks very much. Thumbs Up Found it now.
Does anyone know if there will be any difference in sound quality using an Aux to USB cable?
Post #283125 27th Sep 2014 5:45pm
Weegie
To burn MP3 discs burn them as data discs NOT audio discs. I did that and have no problems with them being recognised or with structure or layers. Just straightforward burn to disc. HTH John
GAP iiD BT-Sold
Post #283129 27th Sep 2014 6:00pm
Arkle
Thanks. Thumbs Up
I'll try to play my music through the AUX/USB first and if that doesn't work, I'll be using the CD's as you suggest.
Post #283136 27th Sep 2014 6:48pm
Sorry......
Memory stick won't work in aux sockets, need an MP3 player, or phone with audio to use them. And then you can only control the music through the device not the car.
They are analogue only, so playing music through them will require something with a headphone out jack or way to output to phono jacks or 3.5mm jack. You will not be able to plug your memory stick into the car directly and have control on the screen unless you have something like craig suggested. There is nothing that can't be fixed with a hammer😜😜
Post #283141 27th Sep 2014 7:15pm
