![]() | Home > Maintenance & Mods (L322) > Engine blower running all the time? |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
Have seen wires damaged at the viscous van hub, causing the fan to run on all time
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
try pulling the fuse for a bit alan.. ... - .- -.
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
Which one Stan? I can't see a number that refers to the engine fan |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Is this the HVAC fan or the engine/radiator electric fan that keeps running? - if the former could be FSR related? .
It seems to coming from the big blower unit at the back of the engine bay, closest to the windscreen. It's not the fan at the front, and it vents out of the bonnet grill.
The interior blower still uses an FSR |
Can I pull a fuse to test and stop it flattening the battery? Got - 2017 SDV8 Autobiography in Loire Blue
i think its fuse 34 but not 100%... ... - .- -.
OK, its not engine related by the sound of things, either HVAC (in which case I reckon FSR) or possibly even FBH on the go?
Put the battery on charge last night and had a quick go at pulling out fuses 12 & 34, which I believe are both A/C related. Blowers still comes on as soon as the battery is connected.
Got home tonight. Tried fuse 59, same problem.
Just a quick update to say the problem was indeed the FSR.
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
| All times are GMT |
