![]() | Home > In Car Electronics (L322) > Reversing Camera Pal Or NTSC? |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
funny that, my 03 shows PAL and NTSC on the screen settings for the tv, my camera supports both..... but only works on NTSC |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 ![]() ![]() ![]() |
Yer it's weird I can't find a way of forcing it to stay in ntsc mode I'm guessing it can't be done on touch screen cars?
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 879 ![]() ![]() ![]() |
It's definitely NTSC as I tested the connections with a PAL home surveillance camera and the image was B/W... |
Thanks adara, does this mean that the touchscreen cars need a ntsc camera or is it just the earlier none touch screen ones that are ntsc?
Mine is touchscreen and it still needs NTSC. But it's easy to test through the 753 secret menu... |
I've done the test through the 753 menu. He has ordered another camera in ntsc format. Will let you know how we get on fitting it over the weekend.
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 ![]() ![]() ![]() |
The reverse cam is opposite to what the TV input is , this is to stop you feeding TV in to the screen while in motion using the reverse cam input
Thanks for all the input. Problem solved and a ntsc camera has been fitted and is now working. Just to let anyone else know that needs to swap there's. The difference between theory and reality is that in theory it will work. |
