![]() | Home > Technical (L322) > Timing Chain replacement/Engine Out |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 ![]() ![]() ![]() |
Good Pic's, it must be a bloke thing but theres nothing better on a friday in my opinion than looking at step by step pictures of a nice lump being removed! |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
I am not bad with a spanner - but your pictures scare the life out of me.
Wow very impressive look foward to rest of pics. I hope this isnt typical of the tdv8 ..
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
I don't think he's done it himself.... "So here goes the picture story of the visits I've made to the shop."
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Following with interest. |
Looks like only thing needed to remove was a tea towel . Very underrated the tea towel |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
Very interesting, hell of a lot of work for a timing chain, but with all the front off the car could you not replace
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
I'm guessing, looking at the pictures, that the engine has to come out in order to remove the sump.
Yep ok, I see that but, looking at one of the pictures showing the right front corner of the engine it looks like you can do the same as on the old classic drop the front line of bolts out of the T/c cover leave the sump in place
Why is that because it looks like you have access to all of it from the front - what's in the way that requires engine removal? |
I'm with you guys but unlike the classic which had a central cam between the V the TDV8 has two banks of cams to drive and it does appear that the chain passes through the block - similar to the Stag V8.
[i]Still doesn't explain why the engine has to come out unless as mentioned the sump has to come off in order to remove the crankshaft timing chest cover.[/i]
I've never pulled one apart either but just looking for reasons why his "experts" all agree it has to come out.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Ever tried taking the injectors or cam covers off a TDV8 with the engine in place? |
