Home > Technical (L322) > Rear passenger air con
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
My rangey has the normal rear passenger controls, one for fan speed and one for temperature. Now no matter where I put the temperature control it only blows cold air. Even when the front ones aren't blowing hardly any warm air at all. I've done a quick search but couldn't find anything. I'm I doing something wrong or is there something wrong somewhere else? Ta.
Post #290730 4th Nov 2014 9:16pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Press the "Rear Control Isolation Switch" on. It's usually located on the front central control panel bottom left (thanks Ian) and looks like a picture of the rear half of the car with 2 wind arrows pointing towards the rear.
It isolates all rear control operation to stop the kiddies playing Thumbs Up
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #290897 5th Nov 2014 12:01pm
T24RES
bottom left switch Thumbs Up
 Ian
Post #290914 5th Nov 2014 12:44pm
Lad
Yes, I saw that and pressed it but still cool air came out. I don't think the fan speed increases either. I had a play this aft, and I did get warm air out but I pressed Max Air Con or something, top left button.
By the way, the heater is normally on normal aircon, not max or the button below and when i turn the temp up to top temp it doesn't start blowing warm air out until i press the max aircon button. Embarassed
Ian, that gear lever seem a bit to far to the LEFT Whistle
Post #291017 5th Nov 2014 7:54pm
not sure but the heat/cold might be in unison with the center dash air vent control, the one just above the hazard switch... ... - .- -.
Post #291019 5th Nov 2014 8:06pm
Lad
Stan that temp control is on warm. I know it will give out warm air as I got it to do it, but I'll play tomoz as I'm trying something else out on it and see what settings I have changed. Thumbs Up
Post #291042 5th Nov 2014 10:00pm
