Home > Technical (L322) > Instruments
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Instruments
Advice please team, I am not sure if this should be in technical electronic or maintenance treads so start here.
On start up the instrument needles "tick" for a few seconds then stay in their home positions, turning off and back on sometimes cures it or not. It has been ongoing for a few months and seems to be getting worse. Only the speedo tacho fuel and temp gauges are affected.
I have had the instrument cluster out when replacing the back lights so checked all the connections then.
Any ideas appreciated or if anyone has a spare cluster I could try?
Thanks Andy Mine was a blue one! Smile
Post #293191 15th Nov 2014 4:09pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Hi Andy. You really have had a run of bad luck lately.
Not sure if it helps but there is a test accessed by the 2 buttons on the console which cycles the dials through all their ranges.
Maybe in the wiki secret codes
.. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #293221 15th Nov 2014 6:42pm
Andy3681
Hi
Yes found that if they are working the instruments test normally if they are in one they just "tick" so I suspect it's just the instruments but that seems to open a whole new can of worms about replacement. Mine was a blue one! Smile
Post #293405 16th Nov 2014 10:25am
Andy3681
Bump.
Anyone had similar or any advice on where to get cluster repaired or if I get a replacement is it a straight swop but I believe it might throw up a "spot" on the milometer?
Thanks Mine was a blue one! Smile
Post #306034 18th Jan 2015 12:25pm
These folk are one of the leading repairers...
http://www.bba-reman.com/uk/index.aspx
Several ads on ebay for repairs, mostly the pixel issue but some of them will do more....
A second hand one will make it look like it's been clocked and could effect resale.... Pete
-Click here for Thread-
Post #306039 18th Jan 2015 12:41pm
Any other electrical gremlins ?
Ours did something similar when we had a duff battery. We also had a few other random lights, seat not moving when using the other key etc.
The battery showed as faulty on a garage tester, with a new battery, all is OK
Post #306044 18th Jan 2015 12:51pm
Andy3681
Thought about the battery I have given it a good charge, it didn't seem to make any difference but the fault is intermittent, only other issue is air suspension warning coming on and off. If I look at off road screen while the message is on all four wheels show the little red icons are at the bottom of the wheels then after a few minutes it goes back to normal with icons in their normal position? Mine was a blue one! Smile
Post #306055 18th Jan 2015 1:41pm
Mine seemed to charge ok, but a proper battery tester showed it as defective.
I'm not sure exactly what the problem was, the machine just said that it needed replacing.
Halfords and others should test it for free, so worth checking.
Post #306057 18th Jan 2015 1:46pm
