Home > Technical (L322) > What are these all about?
MattChaloner
England 2016 Range Rover Vogue TDV6 Loire Blue
Sort of like bump strip door protector things, but they don't seem to be standard?
Anyone know where they come from and more importantly can they be removed or will the doors have been hacked up in order to fit these things?
Also with these, are they easily removable without leaving lasting signs or will there be drill holes that were made to fasten them on?
Looking at a FF with both of these fitted, but would prefer it without these extras!
Thanks in advance
Post #294218 19th Nov 2014 8:38pm
Not sure about the side protectors but would assume they aren't just stick on.
The front light grilles can be removed but are fixed to the wings by rivnuts, so will leave 2 holes in each wing...... Not ideal.
Made the same mistake myself, ended up having the holes ally welded up and the wing painted. Pita..... There is nothing that can't be fixed with a hammer😜😜
Post #294224 19th Nov 2014 9:13pm
CEEGEE
They look like old RR Sport HSE 19" wheels on the top one - not fullfat wheels Whistle
Post #294231 19th Nov 2014 9:26pm
They are stuck on with a double sided tape running all round the edges.
Removing them won't cause a problem unless they have been stuck over some damage.
They appear to be genuine FFRR accessories which are now unavailable so could be quite sell-able.
The best way to get them off is to inset a thin rigid piece of plastic along the top edge and then run it along the edge cutting the double sided tape as you go. Do the top and end edges, peel back and do the bottom edge.
Once removed you will find a strip of adhesive which you can remove by soaking with white spirit or WD 40. Once removed clean and polish, you'll never know they had been there. Thumbs Up
Post #294234 19th Nov 2014 9:40pm
So not riveted on then, but the grilles still a pain.
Recommend a toffee wheel for removing the sticky stuff, go slow and easy with it tho. There is nothing that can't be fixed with a hammer😜😜
Post #294235 19th Nov 2014 10:02pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
I saw a RR close to me for sale but it had those side things on, put me off the car to be honest as like said above i was worried how hard they would be to get off and if there covering anything up
Post #294309 20th Nov 2014 9:51am
Make sure the paint around them is original too... Seen body shops mask around them and paint the lower section of the door... So, if you removed them you would be left with a bit of a mare sir Whistle
Post #294311 20th Nov 2014 10:06am
nobbyclark
The side strips are stick on and are the same as the ones I had on my D3. They were also the same part # for the RRS. If you position them right, they will stop car park dings from other peoples' doors. They will also, in my experience, eventually peel off. I went through 2 sets. They don't peel paint when they come off, but they do leave a lot of difficult to remove glue from the double-sided tape.
As to the headlamp grilles, on the Disco they attached via a bit of metal that went between the light and the bodywork, so they could be fitted without any additional drilling.
Post #294375 20th Nov 2014 2:24pm
