Home > Maintenance & Mods (L322) > L322 air con pressure help
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Yes , that was my understanding of the procedure, however if my gap tool is telling me there is 6.5 psi or bar then the compressor should be working so I’ll need to investigate that first then get a canister online since Halfords are not being very helpful! Thanks
Post #477897 10th May 2018 7:00am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
That is with the aircon on full RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #477922 10th May 2018 10:19am
alfapat
Yes dial right down and gap tool telling me the same , checked two fuses in passenger side under air conditioning but both ok , will have to do a search for the relay and further fuses for compressor , I would have thought that that pressure should energise it, what I don’t know is what side that reading is taken off , low or high?
Post #477963 10th May 2018 8:09pm
knares
red is high
blue is low
i only use the blue line RR 2005 4.4 petrol
Post #477994 10th May 2018 11:50pm
alfapat
Yep I know , but if the diagnostic is taking the pressure reading off the high pressure line then , to me , the compressor should kick in when asked at 5.3 bar.
Sorry I don’t have colours to my lines , and I have a manifold application that does both lines but I know where your coming from.
Post #477999 11th May 2018 6:51am
knares
5.3bar, yes i wasn’t thinking about that, i don’t know what the high pressure side should read RR 2005 4.4 petrol
Post #478011 11th May 2018 9:46am
knares
Have you checked to see if you have power to the compressor, perhaps the clutch is not working RR 2005 4.4 petrol
Post #478012 11th May 2018 9:51am
alfapat
Thanks for your reply , yes I know it’s not working , the clutch is not coming in, so when Iget home this pm I’ll further investigate, basically looking for power at the compressor terminal and or at the relay for it , do you know where the relay would be ? Cheers Pat
Post #478017 11th May 2018 10:41am
knares
no, no idea RR 2005 4.4 petrol
Post #478020 11th May 2018 11:06am
knares
got this else ware, it was his fusebox
A/c compressor now working !!
I got home on Thursday and fitted the brand new fuse box that evening, no compressor and "0" voltage at the compressor.
The next morning I checked all the wiring had been reconnected after I had last looked at it, and there was no problem there.
I did have voltage previously, even if it was incorrect, so I wondered if the garage had removed the gas when they attempted to check the pressures just before I went back to sea.
Took the car in this morning, they put it on the machine, did a full system check and refilled with gas (it had been empty ).
Started the car...a/c working!
So all my troubles actually related to a bad fuse box.
Thanks to everybody that chimed in with suggestions and helpful information.
Regards
Don RR 2005 4.4 petrol
Post #478021 11th May 2018 11:34am
knares
Was looking at my gauges today, I don’t know but I think the high side should be about 150/160psi
Which is about 10bar
5bar is to high for the low side and to low for the high side, if that reading is the high side, perhaps its not high enough to kick the clutch in RR 2005 4.4 petrol
Post #478264 13th May 2018 1:27pm
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
alfapat wrote:
So about 7kg not much needed but how much to start with and was the compressor going before you did it?
Please do not try and put 7kg in !
Post #718798 29th May 2025 7:51pm
